Error 71 problem
Hi guys i switched to zorin a few months ago and its going great, however I have one issue that i don/t know how to fix. Whenever i leave my pc in sleep mode for too long, it starts showing this error and the only way to close it is by force restarting. Does anyone know how to fix this? Thanks a lot!
Both of these errors are due to USB protocol dropping out.
It is a clue, more than a diagnositic.
They could be casual or could be a symptom.
Are you using USB-C or a dock?
To jump at @Aravisian's Question: Do You have any USB Sticks (incl. Dongles) or external Drives plugged in?
i obviousl have a mouse and keyboard, also a controller and a cooling pad plugged in. Is that what's causing the issue?
nope, just the basics like mouse and keyboard, also a cooling pad
Could You unplug this and then try again? Only for testing.
ill try, but I can go a wholle day without this error so it may take a while
That's fine. Test it and report back.
