Ok thanks.
Try
export PATH="/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin"
Watching it now
That worked!!! Thanks so much!! I really appreciate it.
Anytime, please mark the thread as solved. Enjoy your Zorin installation
Good job Michel!
I remember that some commands are common between Linux and OSX when I was running Hackintosh
I figured out another way. Just add this at the bottom of your .bashrc file. That way you won’t have to run that command all the time.
