Error, pleases copy and paste disk
Do not copy folder to another disk in zorin os, the option is disabled. I can't copy file from a hard drive to another partition.
Maybe you are using Windows alongside Zorin OS and you didn't shut down it properly
We need a bit more precise info. First you say you are trying to copy a folder to another disk, then you say partition. Which is it? And what is the folder? System folders outside of /home can't be copied.
Do need a bit more but, if you right click the disk you're trying to copy files to, look under the 'Permissions' tab - what do you have? That disk / partition might be mounting as read-only..
