Getting Error opening source
Error (0, h.requestMetadata) is not a function
This happens when I press flash from file
Do you have already tried to run BalenaEtcher as administrator?
BalenaEtcher often makes problems when creating the boot stick. You could try another program like Rufus (if you have a Windows computer) or Ventoy.
+1 on Ventoy. It's frankly much simpler to use and more reliable. Setting it up is a bit more involved but not all that bad, it's definitely worth trying.
For reference, see also:
Thank you. I went to the Balena forum link and they said to run as administrator. I worked fine.
Only to add an Alternative here: I use on Zorin Impression which works fine for me. The only Downside of it is that You can't choose between GPT and MBR.
