Hi,
I am getting some errors while booting, but it is so fast so I can not take a picture of it.
How can I check if it is something important ?
Maybe some logs in system after boot ?
Thanks
Hi,
Thanks
Yes, try /var/log/syslog
that is a lot.. need to search for errors
Fine then. Try /var/log/boot.log
nothing visible or important xD
I found few of them in /var/log/syslog..
Just need to find a way how to sort them out..maybe google knows, will see
