WiFi and Ethernet are both not working, here's what sudo lshw -c network gave out
What is the output of
rfkill list
Disable fast startup in Windows' energy settings (if you use a Dualboot with Windows).
Also, is Secure Boot enabled in BIOS settings?
Secure boot is enabled and I saw in bios that fast boot was off, no windows
Can you test with Secure Boot disabled?
Still no Ethernet or WiFi
What is your terminal output of:
dpkg -l | grep $(uname -r)
I do not see the modules-extra package.
Can you install it:
sudo apt install linux-modules-extra-$(uname -r)
Then reboot and test?
As there are many problems since the
update to kernel 6.17, you can also test if switching to kernel 6.14 solves the problem. Press continuosly esc (or left shift key if you have a legacy BIOS) during boot to show the grub menu. Then select "Advanced options for Zorin" and select kernel 6.14 to boot from.
