Broad band supplier speed up to 250mbs
only getting approx 100mbs
*-network
product: 82579LM Gigabit Network Connection (Lewisville)
vendor: Intel Corporation
physical id: 19
bus info: pci@0000:00:19.0
logical name: eno1
version: 04
serial: 00:22:4d:7e:e1:46
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.15.0-94-generic duplex=full firmware=0.13-4 ip=192.168.0.211 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:29 memory:fb100000-fb11ffff memory:fb128000-fb128fff ioport:f040(size=32)
*-network
I have tried several 5e cables
any help would be appreciated
I have encountered this, as well. Tried Cat 6 cables - several. Then later, plugging in at a different port resolved the issue.
If a Cat 6 cable is not available to test, try using different ports. These are constricted by the cable, not the driver software, so it is usually a cable issue.
Maybe this is the Point.
I would say try a Cat7 Cable. I have one too and it works well.
Hi all thanks for your help
I use the internet for ordinary things I dont use it much
however
Its that my service provider gives me up to 250Mbits/s
and
my connection is is 100Mbits/s
I have checked router and my mtu is set at 1500 on router and nic
I also have a 5e cable twisted pairs
5e markings on cable
Your Provider can give You 250 and Your Connection is 100. So, do You have a Rate for the 250?
system
Closed
28 May 2024 22:11
9
