Hi,
I was reading your conversation I have the same problem only that I use ethernet with a broadcom nextrem ethernet, but in windows 10 I also disconnected the network when rebooting the connection returned, I wanted to mention it in case you can find the detail, they are obsolete drivers or not compatible 100%, the other I have read that Realtek is not so compatible with Linux distribution.
It is a common problem with ethernet RJ45 connectors (also RJ11 and similar connectors) that have plastic tangs. They become weak and do not spring back fully to "click" in.
Sometimes the tang can be carefully bent backwards to give more spring and a positive click. Otherwise crimp a new cable connector or buy a new cable.
