My PC consistently hangs every 2-5 minutes. It acts like this since 2 days ago. How do I return it to normal?
inxi -Faz output:
System:
Kernel: 5.13.0-27-generic x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13.0-27-generic
root=UUID=04e2c40d-a9ea-4134-8027-3f1a2c83f1ee ro quiet splash
vt.handoff=7
Desktop: Xfce 4.16.0 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Zorin OS 16 base: Ubuntu 20.04 LTS Focal
Machine:
Type: Laptop System: AVITA product: NE14A2 v: N/A serial:
Chassis: type: 10 serial:
Mobo: AVITA model: 6814GCWC40 serial: UEFI: American Megatrends
v: BSR7IPHK-6814R4-AVI-V03 date: 01/12/2021
Battery:
ID-1: BAT0 charge: 15.4 Wh condition: 23.7/23.7 Wh (100%) volts: 7.9/7.4
model: GDPT CN6814-2S type: Unknown serial: status: Charging
CPU:
Topology: Dual Core model: Intel Celeron N4000 bits: 64 type: MCP
arch: Goldmont Plus family: 6 model-id: 7A (122) stepping: 1 microcode: 36
L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 4377
Speed: 801 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 801 2: 949
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown mitigation: PTI
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel UHD Graphics 605 driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:3185
Display: x11 server: X.Org 1.20.13 driver: modesetting
unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 21.0.3
direct render: Yes
Audio:
Device-1: Intel vendor: Realtek driver: snd_hda_intel v: kernel
bus ID: 00:0e.0 chip ID: 8086:3198
Sound Server: ALSA v: k5.13.0-27-generic
Network:
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce v: N/A port: e000 bus ID: 01:00.0 chip ID: 10ec:c821
IF: wlp1s0 state: up mac:
Drives:
Local Storage: total: 119.24 GiB used: 14.16 GiB (11.9%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/sda vendor: Foresee model: 128GB SSD size: 119.24 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: rev: 117H scheme: GPT
Partition:
ID-1: / raw size: 44.84 GiB size: 43.89 GiB (97.87%)
used: 14.13 GiB (32.2%) fs: ext4 dev: /dev/sda5
Sensors:
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 190 Uptime: 2m Memory: 3.66 GiB used: 660.6 MiB (17.6%)
Init: systemd v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Shell: bash
v: 5.0.17 running in: xfce4-terminal inxi: 3.0.38
Zorin version: 16 Lite
Dual boot with Windows 11
