Every 2-5 minutes, my PC hangs
Yes, it hangs on the live USB drive as well.
I take this as further demonstration that the computer itself may be having an issue. Can you try @Storm 's suggestion of blasting dust out of the cooling vents of the notebook?
Given that the kernel does not seem to be the culprit and you state you have not installed anything within the timeframe (Virtualbox would not have this effect) that is a likely cause...
I think cooling your notebook may be the next tip.
@Anonymous7641 Do you use firefox browser ?
Marked solution. 258
Yes, I do.
For some reason, my notebook doesn't have any cooling vents.
I clean installed Zorin and the problem is gone for now.
