Is roblox a webbrowser game ?
No -------
I asked it because i went to their site and needed to use login and password
Thanks for the explanation!
So it is a Wine for abstainers
Yes Lol
Your running the latest nvidia drivers ? Not using the nouveau driver ?
I think so
Can you check if you have a nvidia-x-server settings app ?
How do I check that
Open panel and use search ? Write nvidia
Or in terminal write: nvidia-settings
Brrings me to a empty screen
Means no driver is installed, you have to install them first.
how do i install the drivers (Sorry I'm so used to windows)
- Open the Zorin Menu and go to "System Tools" → "Software Updater"
- After the Software Updater has finished checking for updates, please click on "Settings…"
- Navigate to the "Additional Drivers" tab.
- After a moment, you should see a list of graphics drivers available for your computer. Please select the radio button beside the newest or recommended version of the "NVIDIA driver" to activate this driver software.
- Click "Apply Changes". This will start downloading and installing the NVIDIA proprietary drivers.
- After the installation completes, you will need to restart your computer.
Select the 495.44
Okay done I'm heading into the nvidiaerver
Apply and reboot and try your game
Oh okay should it be solved after that?
I think the latest is .470
470.86 is not stable, black screen issues on my gtx 1070 card
