You can reinstall windows and then I suggest you to look to q4os if you want a Linux distro: it's installable directly from windows, without an USB or modifing (correct?) the os currently installed
I will look into it. Thanks for the suggestion.
Hey guys, I successfully installed Garuda OS. Thanks for all the response for my query.
