It seems it's not possible to pick a solid background color, unless you create an image. This should be possible. Thank you.
As an alternative, at least until this is included (if it is), it can be set through the terminal in two steps:
First, remove the background pictures for light and dark themes:
gsettings set org.gnome.desktop.background picture-uri none gsettings set org.gnome.desktop.background picture-uri-dark none -
Then, update the background color:
gsettings set org.gnome.desktop.background primary-color 'red'The color can be specified by name or in hexadecimal format. I'm not sure which other formats are supported. For a list of names available, check this website:
EDIT: It seem HSL is also supported, so I guess anything that is valid in CSS. You can use tools like "gpick" or "Eyedroopper" from the software store to pick colors out of the screen.
Do note that after modifying the background theme using Zorin Appearance, the background picture will be reset, and you'll have to unset it again. This would actually be a good addition to another script to control these settings, as discussed here:
This is why I prefer Plasma. Gnome Devs failed the users again by removing solid colours, essential for users with low-vision.
