Fingerprint reader doesn't work
Hi,
I’m using Zorin OS 18 on a Lenovo ThinkBook 15 IIL.
My fingerprint sensor is detected in lsusb as:
27c6:55a4 Goodix Fingerprint Device
However, fprintd gives:
"No devices available"
Is this sensor supported in Zorin OS / libfprint, or is there any workaround or driver?
Thanks!
you can take a look at this maybe it will help you
https://ubuntuhandbook.org/index.php/2024/02/fingerprint-reader-t480s/
Hi and welcome.
Having done a search there is an experimental package for the ':55b4' but nothing for the ':55a4'.
I think your only option if it is crucial that you have one is to purchase dedicated fingerprint reader that is compatible with the Linux kernel, but not cheap:
$139
I found no reports that this fingerprint reader worked in Ubuntu 22.04 or 24.04
thanks for the help... its a bit annoying that it doesnt work, i ve recently fully moved to linux, im still a begginer but i really like zorin os, i ve had enough with microslop :))) anyway, im waiting maybe in the future they ll make something available for my sensor too
