Fix wine not working with installed apps
well, wine works fine with the apps i open on files manager, but when i launch them from the application menu, it doesn't launch like it was, idk, maybe it was caused by osu-winello, because i saw like it installing wine-staging dependencies or what,
Don't know if this helps:
all the apps was there in the app list tho, but still it does not open
I suspect this might be because wine works inside its own area of RAM. If you run wine.config, you can create a wine desktop where the icons of installed apps reside, and you can launch them from the wine 'desktop'. I know it is not the same as running from the menu.
yea. i hope i get a real solution, when i'll get a new usb. i'' reinstall or just install a new distro
