Folding@Home on Zorin OS 18
Edit: SOLVED. If you are using Brave browser, just disable the shield functionality for the web ui portal and it will begin to work correctly.
I downloaded the fah-client_8.4.9_amd64.deb installation package from Start Folding – Folding@home. It seemed to install properly since I didn't get any errors. After installation, I launched the app from my start menu and it directed me to the web UI, where I managed to login to the service. However, it doesn't seem to be able to connect to my PC? When I view open processes with system monitor, I don't see anything FAH related running on my machine -- which I am guessing I should have right? How should I proceed?
For context, I have Windows 11 installed on another SSD with the FAH client and I can run it just fine there, so at least there shouldnt be any router or network related issues at play here. And when I log in to the FAH web portal on Zorin it does show my Win 11 machine there in "Disconnected" state. But no sign of this Zorin machine there.
Funny, in hindsight it seems so clear...
