Gkr-pam errors since install of Zorin OS Pro
Do research on the errors in the log profile keep pointing me to the AMD Graphics driver. MY graphics is also part of my cpu. So this might be a driver issue.
Do we have a driver for the "AMD Ryzen™ AI 9 HX 370 w/ Radeon™ 890M × 24"?, yet?
The driver is included in the kernel. You could try upgrading the kernel. to 6.19.x
It may be harmless warnings, so if it works you could leave it with that.
Do You have any functional Issues with Your System at the Moment?
So I created a ticket for my system restarting last month, and I thought we sidestepped the problem because I changed the settings. here is the link to the issue Every night Zorin OS 18 Pro goes to black screens and restarts
Now the system will restart when using Brave and the file manager together. with the GKR-pam errors.
I will also look into how to upgrade the kernel to 6.19.x.
you can also tale a look at this
did you try to switch to X11 instead of Wayland ?
Sorry for the late reply. Life happened for a few days.
The above did not work. I have tried X11 and get the same errors, but it pointed me to a memory issue also.
Found and fixed.
Found: that there was a memory leak that was actually causing the restarts. Wayland restarted before the memory was full. Once I switched over to X11 it did not restart until the memory was full. So I put a logged on the system and found that one tab in the brave browser was leaking memory.
Fix:
Switched to firefox and ran the same tab. no memory leaks and the system has not restarted yet.
Thanks Everyone for your help on this
I think the reason for the gkr-pam errors is the daemon control file (gkr-pam) is NOT present in the folder /etc/pam.d/
Looking for control file in pam.d folder:
scott@scott-Falcon-Talon:/etc/pam.d$ ls -l gkr*
ls: cannot access 'gkr*': No such file or directory
Contents of the pam.d foler:
scott@scott-Falcon-Talon:/etc/pam.d$ ls -ltr
total 116
-rw-r--r-- 1 root root 168 Aug 18 2022 ppp
-rw-r--r-- 1 root root 520 Oct 13 2022 other
-rw-r--r-- 1 root root 315 Jan 29 2024 sudo-i
-rw-r--r-- 1 root root 330 Jan 29 2024 sudo
-rw-r--r-- 1 root root 92 Feb 22 2024 passwd
-rw-r--r-- 1 root root 92 Feb 22 2024 newusers
-rw-r--r-- 1 root root 581 Feb 22 2024 chsh
-rw-r--r-- 1 root root 92 Feb 22 2024 chpasswd
-rw-r--r-- 1 root root 384 Feb 22 2024 chfn
-rw-r--r-- 1 root root 606 Feb 26 2024 cron
-rw-r--r-- 1 root root 69 Feb 28 2024 cups
-rw-r--r-- 1 root root 137 Mar 3 2024 su-l
-rw-r--r-- 1 root root 2259 Mar 3 2024 su
-rw-r--r-- 1 root root 138 Mar 3 2024 runuser-l
-rw-r--r-- 1 root root 143 Mar 3 2024 runuser
-rw-r--r-- 1 root root 4118 Apr 9 2024 login
-rw-r--r-- 1 root root 1452 Dec 2 2024 gdm-smartcard-sssd-or-password
-rw-r--r-- 1 root root 1675 Dec 2 2024 gdm-smartcard-sssd-exclusive
-rw-r--r-- 1 root root 1717 Dec 2 2024 gdm-smartcard-pkcs11-exclusive
-rw-r--r-- 1 root root 1320 Dec 2 2024 gdm-password
-rw-r--r-- 1 root root 383 Dec 2 2024 gdm-launch-environment
-rw-r--r-- 1 root root 1342 Dec 2 2024 gdm-fingerprint
-rw-r--r-- 1 root root 1192 Dec 2 2024 gdm-autologin
lrwxrwxrwx 1 root root 31 Feb 13 08:28 gdm-smartcard -> /etc/alternatives/gdm-smartcard
-rw-r--r-- 1 root root 1300 Apr 4 09:01 common-auth
-rw-r--r-- 1 root root 1312 Apr 4 09:01 common-account
-rw-r--r-- 1 root root 1778 Apr 4 09:01 common-password
-rw-r--r-- 1 root root 1458 Apr 4 09:01 common-session
-rw-r--r-- 1 root root 1435 Apr 4 09:01 common-session-noninteractive
