Hi, I have installed Zorin OS 16 on my Mac mini 2019 (intel i3). Work perfectly, but headphones/microphone jack port not work. Suggest?
Hello, try first with;
alsamixer
in the terminal and check if they are muted or very low.
Edit:
you ca also try with this app;
sudo ap install pavucontrol
