Hello again. Suddenly the jack for my headphones stopped working, I'm unsure of what the problem could be at this time. My computer's been having issues in general as of today with staying connected to the wifi as well as no longer picking up on my earbuds when they're plugged in. I've tried restarting, checking for additional updates, and so on. I've also tried downloading other things like pavucontrol, and using alsamixer. any help at all would be greatly appreciated.
You could try to boot into an older kernel to test if the issue is caused by a kernel update. At grub menu select advanced options for Zorin and then select an older kernel to boot from.
If the grub menu isn't displayed at boot press continuosly esc (or left shift key if you have a legacy BIOS) to make it appear.
