I have a trouble with zorin os, i can't open any app and can't open the terminal, i'm stuck with this screen, i've tried to reboot but it doesnt works. Someone knows how to fix it?
Solved my issue. If anyone doesn't know how to fix it, follow these steps:
- Restart your computer.
- Enter Recovery Mode and open the bash terminal from there.
- Restart GNOME, or — if your case is like mine — delete the broken cursor you downloaded.
- Exit the terminal.
- Continue to boot into the system and check if everything is back to normal.
- Restart once more, and you're all set.
Could you name the cursed cursor to help others?
