To give some context... My computer was shutoff improperly and when I managed to boot it again, it was stuck at 1024x768 resolution (4:3), the display partition is under:
xrandr-None-1 Monitor
While my monitor's (LG Ultragear 24') resolution is 1920x1080! For more context, I attempted to re-install NVIDIA drivers to no avail, I attempted to add new resolution through xrandar to no avail, and I attempted to simply plug out and plug back in my monitor to, yet again, no avail!
Here is what comes up when typing
xrandr
Screen 0: minimum 16 x 16, current 1024 x 768, maximum 32767 x 32767
None-1 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 270mm x 203mm
1024x768 59.92*+
800x600 59.86
640x480 59.38
320x240 59.52
960x600 59.63
928x580 59.88
800x500 59.50
768x480 59.90
720x480 59.71
640x400 59.95
320x200 58.96
1024x576 59.90
864x486 59.92
720x400 59.55
640x350 59.77
as well as
inxi -Ga
inxi -Ga
Graphics:
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: N/A arch: Gen-9.5 process: Intel 14nm built: 2016-20 bus-ID: 00:02.0
chip-ID: 8086:9bc5 class-ID: 0300
Device-2: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: N/A
alternate: nvidiafb non-free: 550.xx+ status: current (as of 2024-04;
EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: wayland server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
compositor: gnome-shell v: 46.0 driver: dri: swrast gpu: N/A display-ID: :0
screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.63x7.99")
s-diag: 338mm (13.3")
Monitor-1: Unknown-1 mapped: None-1 res: 1024x768 hz: 60 dpi: 96
size: 270x203mm (10.63x7.99") modes: 1024x768
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
wayland: drv: swrast x11: drv: swrast inactive: gbm
API: OpenGL v: 4.5 vendor: mesa v: 25.2.8-0ubuntu0.24.04.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 20.1.2 256 bits)
device-ID: ffffffff:ffffffff memory: 30.43 GiB unified: yes
and here are my system specs: # System Details Report
Report details
- Date generated: 2026-03-15 03:33:26
Hardware Information:
- Hardware Model: ASUS PRIME H510M-A
- Memory: 32.0 GiB
- Processor: Intel® Core™ i7-10700 × 16
- Graphics: Software Rendering
- Disk Capacity: 1.0 TB
Software Information:
- Firmware Version: 1203
- OS Name: Zorin OS 18 Core
- OS Build: (null)
- OS Type: 64-bit
- Windowing System: Wayland
- Kernel Version: Linux 6.17.0-19-generic
If anyone can help me out please do!!
