I was on my Zorin PC this morning no issues, turned it off to work. Did not install any new programs, files, etc. Logged in this afternoon and suddenly stuck in login loop (entered password, returned me to enter password screen.)
I followed all of the steps at the following post and associated links: Zorin 17.3 Login loop latest update
- Repair install
- Tried to fix broken packages
- Sudo update & upgrade
- Fall back to older kernel as default via CLI
- Advanced startup options
- Tried reinstalling Zorin OS
- Cleared .cache
- Followed the three methods in this guide (no .Xauthority)
I did see when restarting in the CLI that there were three unsuccessful updates. I opened the log in nano and it didn't tell me much other than there were some grub updates.
Finally what worked was creating a new user. I've successfully logged in as the new user, which seems to tell me based on @Storm 's answer that the config files in my normal user profile are corrupted.
Weirdly, after logging into that profile, I received a message saying there were important UEFI updates installed. Upon reboot, I can get back into my former profile.
What steps should I be taking at this point to verify what caused the issue, if t was a corrupted config, and/or what can resolve it?
