the error is this. so how can I solve that??
Changed title, as "How to" is generally used to describe tutorials.
ok sorry
No apology needed. I was just stating reason for the edit.
I am not familiar with QT5CT, but did a websearch and found this:
Don't know if it is any help to you.
Yes, I have gotten this warning too. I know the feeling.
Elevate to Root with your file manager:
sudo -i
thunar
Hit the up arrow on the toolbar three times to get to the top level of the tree.
Now, navgate to /etc/profile.d/
You will see Two Files in here.
qt-qpa-platformtheme.sh
and
qt-style-override.sh
I blanked out qt-style-override.sh
and saved it as an Empty File.
In qt-qpa-platformtheme.sh
, ensure the contents say only
export QT_QPA_PLATFORMTHEME=qt5ct
and ensure the file is saved.
Now, navigate to /etc/X11/Xsession.d and open 99qt5ct
with text editor.
The contents should be:
# Enable qt5ct by default unless another PLATFORMTHEME option is set
# or KDE is running.
if [ -z "$QT_QPA_PLATFORMTHEME" ] && [ "$XDG_CURRENT_DESKTOP" != "KDE" ]
then
fi
ensure that it is exact, please.
Next
Navigate to /etc/X11/Xsession.d and open 56zorin-os-lite-session
The contents should
# Set default environment vars in Zorin OS Lite
if [ "$DESKTOP_SESSION" = zorin-os-lite ]; then
# QT5 apps to use GTK style
# Workaround clutter issue (LP: #1462445)
export CLUTTER_BACKEND=x11
fi
Ensure it is exact and file saved.
That should be everything.
Do a hard reboot and test.
