I'm new to Linux and made the switch about a month ago. I set up Zorin 18 as my only os and updated to 18.1 when released. I've had this issue from the start and I've tried all the fixes I could find in this forum and elsewhere.
The system freezes regularly without any clear trigger. It usually happens at least once a day. It happened twice yesterday when I first tried to write this post. Things will freeze up but my mouse is still responsive. I have to hard reset with the power button to fix it.
I've disabled secure boot and fast boot. I've disabled sleep functions. I switched to Xorg. I disabled hardware acceleration in Firefox. Everything is up to date.
I'm not savvy enough yet to figure out how to diagnose this issue and would appreciate any help this community can provide.
Here are my specs:
Dell Latitude 7480
Intel Core i5-7300U x 4
Intel HD Graphics 620
8gb RAM
512gb SSD
Kernel 6.17.0-23
Firmware 1.41.3
I like Zorin aside from this issue, and would like to fix it, but would a different distro be more appropriate?
There doesn't seem to be a consistent trigger. Sometimes it happens in Firefox, sometimes when I'm accessing files and settings without Firefox running.
You can test if it helps to add i915.enable_dc=0 to GRUB_CMDLINE_LINUX_DEFAULT line on /etc/default/grub.
I read that it helped also for Dell 7480.
Another grub parameter which you could try instead of the one above is i915.enable_psr=0.
To edit the file you need sudo rights.
Run in terminal
sudo nano /etc/default/grub
then move with the arrows down to the line
and add the term as shown in the link.
Press ctrl+o to save, press enter to confirm and ctrl+x to exit the editor.
Then run
sudo update-grub
and reboot.
If it doesn't help repeat all steps and remove the added term, then update grub again.
Adding such kernel parameter will result in slightly higher power consumption, but unfortunately, this often seems to be the only way to fix the freezes on these Dell laptops.
Reading package lists... Done
Package 'folder-color' is not installed, so not removed
libwoff1 zorin-os-feedback
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I had the same problem with my Zorin OS for a long time, you can use Zorin's builtin extension (or download Resource Monitor - GNOME Shell Extensions) to show cpu/memory usage when it's freezing. If the cause are not them I believe it might be because of dumping logs to disk when an app crashes and so much write to disk was making my desktop unusable. (That was the case for me)
It may be this. I did the previously suggested fix and was hopeful but I just experienced another freeze. First only Firefox froze up and I could still access other windows. Force Quit window came up but clicking it didn't work so I tried to open terminal, but it wouldn't open. Then the whole system froze up.
I will try this.
I did and still experienced the freeze that I described above as well as a second one immediately after that reboot. I did just change the grub parameter to the second suggestion though.
Hola amigo Doze si se trata de congelamiento dentro del navegador es normal en especial en zorin si ocure con todas las paginas pruebalas aver si sigue congelandose a mi me pasa pero no queda congelada del todo si le doy click responder para decir en un foro algo tengo que refrescar la pagina si o si pero no es congelamiento total que no pueda moverme por navegador o escritorio en si sea en windows o en ZOrin tambien pasa . quiza la forma de como esta construido Zorin FORO si solo pasa ahi a mi pero al resto me va bien ..
