Deccided to do a Brave A.I. search on Vivaldi:
" No, the Warsaw banking module does not work with the Vivaldi web browser.
The Warsaw security module, used by Banco do Brasil for online banking, is incompatible with Chromium-based browsers like Vivaldi. This is because the module relies on Java plugins, which modern browsers—including Vivaldi—no longer support due to security concerns. Users have reported that even after installing the module, it fails to function properly in Vivaldi, with the bank's website indicating it is not installed.
Key points:
- Vivaldi is Chromium-based , and does not support Java plugins .
- The Warsaw module requires Java , which is deprecated and unsupported in most modern browsers.
- Alternative solutions include using Firefox (specifically the 52 ESR version, which still supports Java) or running the banking module in a virtual machine to avoid system-wide risks.
For secure and reliable online banking, consider switching to a bank that supports modern, secure browser standards.
I use Vivaldi for occasional account access (settinhg up new account) and had no issues, because I don't use a Brasilian bank.
Using Brave A.I. on how to install on Ubuntu 24.04 on which Zorin 18 is based gives:
"To set up Banco do Brasil Internet Banking on Ubuntu 24.04 , follow these steps using the official Warsaw security module:
Install the Warsaw Security Module
- Check your system architecture :
uname -m
- If it returns
x86_64 , you're on 64-bit.
- If it returns
i686 , use the 32-bit version.
- Download the 64-bit Warsaw installer :
wget https://cloud.gastecnologia.com.br/bb/downloads/ws/warsaw_setup64.deb -O warsaw.deb
- Install the package :
sudo apt install ./warsaw.deb
If dependencies are missing, run:
sudo apt install -f
- Verify installation :
- Ensure the
warsaw service is running:
ps -ef | grep -i warsaw
- Look for processes like
/usr/local/bin/warsaw/core running under both root and your user.
- Restart your system to ensure all components are properly initialized.
Configure Your Browser
- Use Firefox : The Warsaw module works reliably with Firefox.
- Open Firefox and go to
about:preferences#privacy → Certificates → View Certificates .
- Under the Authorities tab, confirm "Warsaw Personal CA" is present.
- Avoid Flatpak browsers : Browsers like Firefox or Chrome installed via Flatpak may not support the module. Use the native system versions instead.
Access Internet Banking
Note : The module is not compatible with Google Chrome when installed via Flatpak or as a snap. Use the native system version of Chrome or stick with Firefox for best results.
I would therefore suggest you install Firefox ESR from a tarball from the official site. I made a video how to do this along with zen and Tor browsers here:
