Once again, sudo nano /etc/default/grub
and after "quiet splash"
add the grub parameter: pci=noaer
ctrl+x
, then y
, then enter
sudo update-grub
Will need to reboot to test...
ctrl+x
, then y
, then enter
sudo update-grub
@Aravisian how should it look after adding the parameter? i assumed it was a space plus pci-noaer with each side possessing "". im a noob. thanks in advance
"quiet splash pci=noaer"
thats what it looks like and i still have codes at start up? am i missing something ? @Aravisian @Ocka
LogLevel=3 means that it will only display serious errors. You are still getting the errors...
I would recommend running a S.M.A.R.T. test. Replace (Device Name) with the actual device name like /dev/sda1
smartctl -a (Device Name)
Check the drive for failures.
The other thing may be that you need to update your BIOS.
