So, i got this when i tried to boot zorin. CTRL + D didnt work,
Rebooting didnt work. None of the commands worked.
The answer might vary with what caused this to happen. But from past experience, press Enter for maintenance, then you can login, and then give a 'reboot' command to restart.
Unless you fixed the problem before the reboot, you will likely end up in the same situation.
rebooting doesnt work
Just read the first line, wat does it tells you to do ?
You are in emergency mode. After logging in type “journalctl -xb” to view system logs.
Did you write this ?
Marked solution. 52
