I have replaced nautilus with nemo using:
sudo apt install nemo
xdg-mime default nemo.desktop inode/directory application/x-gnome-saved-search
gsettings set org.gnome.desktop.background show-desktop-icons false
gsettings set org.nemo.desktop show-desktop-icons true
I also run nemo-desktop
at system startup.
I have also disabled Zorin Desktop Icons
extension.
However, I found that when I click Save As
or Open
on file editors, it open nautilus.
Bellow left side is nemo and right side is nautilus.
Bellow is the screenshot of Save As
of vscode.
You can see from the first screenshot that there is Desktop
in nemo but not in nautilus.
You can also see from the first screenshot that there is no Pictures
in nemo but it is there in nautilus.
You can see from the second screenshot that there is Pictures
but not Desktop
. So it is definitely from Nautilus.
How can I use Nemo for Save As
, Open
etc. Instead of Nautilus
