How do i run osu?
how do i get osu to run, i installed osu back when i was using windows, its stored in my external hard drive
Do you mean the Game osu? If Yes, You can download an AppImage of it from their Website:
Click there on this:
You can use the appimage of osu:
Download it and then make it executable
  1. Open your file manager and browse to the location of the downloaded AppImage (usually Download folder)
  2. Right-click on the AppImage and click the ‘Properties’ entry
  3. Switch to the Permissions tab and
  4. Click the ‘Allow executing file as program’
Then doubleclick on the AppImage.
