I used ZorinOS Pro 16 with Bitwig 4 (paid software)
Update software sources
sudo apt-get update
Install required dependencies if needed
sudo apt-get install apt-transport-https gpgv wget
Buid it
sudo apt install build-essential
sudo apt install manpages-dev
Check
gcc --version
Download package file
wget https://launchpad.net/~kxstudio-debian/+archive/kxstudio/+files/kxstudio-repos_11.1.0_all.deb
Install it
sudo dpkg -i kxstudio-repos_11.1.0_all.deb
sudo apt-get install cardinal
sudo apt install cardinal-vst2 cardinal-vst3 cardinal-clap
1
https://imgur.com/kpYSK7S
2
https://imgur.com/GKQty1P
3
https://imgur.com/DEyybJ1
4
https://imgur.com/rbUffaM
5
https://imgur.com/bvyTKOt
6
https://imgur.com/S8QKdRe
7
https://imgur.com/Xabapa5
8
https://imgur.com/7pzIzPd
9
https://imgur.com/LskBFqj
Finished
https://imgur.com/F4LeKS3
Admins I cant post pictures so im doing the next best thing, the pictures are step by step.
