Hello
I check my computer,update etc and I remeber about bleachbit(flatpak) and when i clean my system I noticed than in ~/.chashe was Jetbraines files from pucharm 2026.1 and...I'm litthe shock because I 2 second time return to backup witchout pycharm 2026.1 and other jetbrains program x) and this in't first time situacion: old firefox folder in home(I purge firefox), old flatpak fodler from brave and I have question:
Is timeshift don't returnet ~/.casche and this is source than folder pycharm 2026.1 was even reutrn system?
How manually find and check files created from programs which I unistall and theshe programs creates?
And is bleachbit in flatpak version will ok to manange old files?
Yes, you can use a tool like bleachbit, stacer or ubuntu cleaner. For flatpaks you can also use the cleaning program flatsweep.
Instead of the Flatpak Version of Bleachbit, You could try the .deb Version. It is in the Repo's. If You want a newer Version, You can download the .deb Version from the Developers Website:
I understood thank you
And...How chock it manually? Using comand? I use sudo find -iname "name" but...is it other options?
What do You mean? Installing it? When You use the Version in the Repo, You can use it in Gnome Software or use the Terminal Command sudo apt install bleachbit
If You download the .deb File from the Developers Website, you can make a Double-Click on it and then Gnome Software opens, where You have to click on the Install Button. Don't be irritated that Gnome Software opens for that; it is the Install Interface.
Another Option would be to use Gdebi. It is a graphical Tool to install .deb Files. You can install it with the Command sudo apt install gdebi
Or You install the downloaded .deb File in the Terminal. You open the Terminal and type sudo dpkg -i and then the Path to the .deb File with the .deb File Name. Or You make cd and then the Path, press Enter and then sudo dpkg -i and Filename.
Thank you
But i mean than are manual options for example: searching not using,old files if i know wchich program he's created etc?
And thank you for this
I don't know than these program existing x)
I have the question: how check changes in folders?
