How to change startup sound?
Hello! I'm back here :slight_smile:
So well, Im on Zorin 16 and is it possible to change the startup sound? Thx
I think you can replace
/usr/share/sounds/zorin/stereo/desktop-login.ogg
with other sound file.
It's read only
If you are using Zorin 16 (Gnome desktop) you can open file manager as root to replace/rename files in the system directory.
sudo nautilus
