I just finished Installing Zorin Os Lite Version, I have a question though! How to create a simple slideshow theme like we do in Windows?
You can download the desired wallpapers, then keep them in one folder ex:-Pictures.
Then right click on the desktop, select desktop settings. Then choose the folder with wallppers which will load all the wallpapers on the OS. You might then be familiar with the other settings below
To Start the theme click on a Picture loaded on the screen and exit.
That did the trick😇
Thanks
For clarity for future readers:
The solution includes checking the box for Change the background
and setting the desired time and whether to randomize the slides.
