when i say flatpak install --no-static-deltas it gives me an error saying At least one REF must be specified what do i do
try run flatpak repair and continue to the installation. If it doesn't work, we need to wait till the flatpak guys fixes the problem.
hey man this is weird can u take me step by step with the terminal way pls?
Yes, ask away when you're in doubt.
i tried to do it no errors but it didn't work
Lets see;
cat ~/.config/autostart/LiveWallpaper.desktop
do i just copy paste or do i change anything?
copy paste till I say so.
Can you give me output of;
cat: /home/marc/.config/autostart/LiveWallpaper.desktop: No such file or directory
Okay did you delete it? If not lets create it.
nano ~/.config/autostart/LiveWallpaper.desktop
add;
[Desktop Entry]
Type=Application
Exec=sh -c "/usr/local/bin/Live.sh"
Hidden=false
NoDisplay=false
X-GNOME-Autostart-enabled=true
Name=Live wallpaper
save ctrl+o
exit ctrl+x
then output of;
do i change anything in
[Desktop Entry]
Type=Application
Hidden=false
NoDisplay=false
Name=Live wallpaper
Nope I done that for you.
[Desktop Entry]
Type=Application
Hidden=false
NoDisplay=false
Name=Live wallpaper
this happens when i paste cat ~/.config/autostart/LiveWallpaper.desktop
So far so good. Lets see the output of;
cat /usr/local/bin/Live.sh
cat: /usr/local/bin/Live.sh: No such file or directory
i think ctrl + o didin't work here because some stuff popped up in the bottom of the terminal and i just ctrl + x i think something should have been pressed after ctrl + o
the cat command showed it was saved.
Okay we need to create that too;
sudo nano /usr/local/bin/Live.sh
add the following;
xwinwrap -fs -fdt -ni -b -nf -- mpv -wid WID --no-audio --loop "/path/to/your/videofile/file.mp4"
where it says /path/to/your/videofile/file.mp4 you need to put the exact path and filename.
ctrl+o save
ctrl+x exit
i get that from the file manager right?
Yes you can use the file manager to get the path and file name.
like this
/home/marc/Videos/LiveWallpaper
but the name of the video is not that LiveWallpaper is the name of my folder
but in the properties of the video this is the location
