Hello,
I wanted to know is there any way to get a network applet in the lock screen with zorin os lite, like you get in gnome? Have checked the lightdm settings but can’t find any network applet.
Thanks.
Hello,
Thanks.
How about Alt+Fn2 -> dconf-editor
-> search for nm-applet
and make sure it’s toggled on for show-in-lock-screen
If there is no dconf-editor then install it using sudo apt install dconf-tools
It’s a bit tricky… For Zorin os LITE, install gtk-greeter-settings
sudo apt-get install -y lightdm-gtk-greeter-settings
Once installed, you need to manually add the network manager.
Ensure you have libapplication installed.
Then in terminal
sudo nano /etc/lightdm/lightdm-gtk-greeter.conf
Add these lines to it:
reader=nm-applet
a11y-states=+reader
Save and exit by hitting ctrl+x, then hit “y” then hit “enter key.”
Reboot.
Now open the lightdm-gtk-greeter-settings app and select all your desired preferences, including that nm-applet is enabled in the panel. Log out and in to test.
EDIT: A little late, but it just occurred to me I should post a source since it gives a lot of other helpful information that anyone can reference in future:
Possible configuration options listed below.
—Appearance:
theme-name = GTK+ theme to use
icon-theme-name = Icon theme to use
background = Background file to use, either an image path or a color (e.g. 772953)
user-background = false|true (“true” by default") Display user background (if available)
transition-duration = Length of time (in milliseconds) to transition between background images (“500” by default)
transition-type = ease-in-out|linear|none (“ease-in-out” by default)
----Fonts:
font-name = Font to use
xft-antialias = false|true Whether to antialias Xft fonts
xft-dpi = Resolution for Xft in dots per inch (e.g. 96)
xft-hintstyle = none|slight|medium|hintfull What degree of hinting to use
xft-rgba = none|rgb|bgr|vrgb|vbgr Type of subpixel antialiasing
—Login window:
active-monitor = Monitor to display greeter window (name or number). Use
cursor value to display greeter at monitor with cursor.
position = x y (“50% 50%” by default) Login window position
default-user-image = Image used as default user icon, path or #icon-name
hide-user-image = false|true (“false” by default)
—Panel:
panel-position = top|bottom (“top” by default)
show-clock = false|true (“false” by default)
clock-format = strftime-format string, e.g. %H:%M
show-indicators = semi-colon “;” separated list of allowed indicator modules. Built-in indicators include “~a11y”, “~language”, “~session”, “~power”. Unity indicators can be represented by short name (e.g. “sound”, “power”), service file name, or absolute path
—Accessibility:
a11y-states = states of accessibility features: “name” - save state on exit, “-name” - disabled at start (default value for unlisted), “+name” - enabled at start. Allowed names: contrast, font, keyboard, reader.
keyboard = command to launch on-screen keyboard (e.g. “onboard”)
keyboard-position = x y[;width height] (“50%,center -0;50% 25%” by default)
reader = command to launch screen reader (e.g. “orca”)
—Security:
allow-debugging = false|true (“false” by default)
screensaver-timeout = Timeout (in seconds) until the screen blanks when the greeter is called as lockscreen
—Template for per-monitor configuration:
[monitor: name]
background = overrides default value
user-background = overrides default value
laptop = false|true (“false” by default) Marks monitor as laptop display
—General Greeter
[greeter]
font-name=
xft-antialias=true
xft-dpi=96
xft-hintstyle=slight
xft-rgba=rgb
show-indicators=
show-clock=true
clock-format=%H:%M
keyboard=
reader=
position=
screensaver-timeout=
When I opened the lightdm settings I found only these:
In the external services and library
can’t seem to find the network applet. Which category here has that or should I have to manually add that?
I just tested this on mine and - it is not working anymore. Back to the drawing board.
That said… You can use GDM instead of LightDM on Linux Lite, if you want to switch…
Switch? I just love Zorin so much had distro hopped to Ubuntu Budgie and Linux Mint in between and have to say Zorin is the most stable distro I have seen so far.
Also can’t we use GDM on Zorin?
Yes, that is all I meant by switching. You can use GDM on Zorin Lite.
Will try that soon and let you know
