Greetings to all, I have Zorin OS PRO 16 copied on my pendrive but I want to update it now, that I do not see from the Distribution not installed to leave it updated, since when installing it it takes a long time because an update is downloaded between them a better kernel of linux, but how do I leave the already updated distribution on the pendrive to only install it with the new?
Updating the "Try Zorin" or installing applications to it will have no effect on the Installed Version of Zorin, since the "Try Zorin" is a Trial to Test the OS with.
I am sorry, but when you install Zorin OS, you must run your updates once installation is completed.
