I tried everything (...I think...) but still cannot print on my Brother DCP-L2550DW
usb or wifi :-(((((
......while I can print using my Samsung phone on Wifi.... grin grin grin
usb or wifi :-(((((
Thank you
I got it all till
If you are asked for your “DeviceURI”, you can find that by opening the Zorin Menu → Settings → Printers → “Additional Printer Settings…”, then right-click your printer and select Properties. In the resulting window, you’ll be able to find your Device URI.
I was unable to select properties and find the Device URI.....
so ..I said "NO" .... and it seems to work
I'm testing now
Thank you
Pierre
Sorry but does anyone know how to delete the current print job?
I need to stop a 100 page print and I have selected to delete it but it just keeps on printing?
Anyone???
