Hi
Is it possible to get Zorin to have a preferred Wifi option if multiple networks are available (more than one of which I've connected to before)?
Thanks
Hi
Thanks
I'm using Cinnamon not Gnome, but if you go into WiFi there should be a history button if you click on that you will see a connect automatically, uncheck it for all you don't want to connect automatically and only leave the one you want.
In gnome. Settings>Wifi
Go to your preferred wifi network, click the settings (gearwheel) and tick the "connect automatically" box. Also tick the "make available to other users" option, if you have other users on your ZorinOS.
Perfect, thank you both. Easy when you know how, I should have thought of that!
Would you mind marking one of their posts as the solution?
