How to solve this problem?
See in taskbar it shows a error message i don't know what it is How to solve this issue
Please open a terminal and run:
sudo apt update
relay any errors or 404 here.
If it runs without errors, please run
sudo apt upgrade
and relay the results of that here...
Working thank you
Incase you have broken packages on your system, In terminal
sudo apt --fix-missing update
sudo apt update
sudo apt install -f
Thank you sir
I recommend sudo apt --fix-broken install instead. This is because "-f" in the sudo apt install -f means "Force the install" and this can cause problems if there is a reason that the install is failing in the first place. It is better to properly install or fix the install than it is to force it.
Thank you, sir
