[HOW TO] Use Battle.Net on Zorin (Diablo 3, Diablo 4)
It looks like you triggered the spam filter threshold repeatedly... my guess is this happened because of the use of "battle.net", which the forum transforms automatically into a URL after creating the post and after a few times thought it was a spam account.
Although it shouldn't be necessary, for now one thing you can do to avoid this (especially being a new account) is add a backslash (\) character infront of the dot: "battle\.net" to avoid the conversion to a URL.
The posts are now restored, but the account seems deleted unfortunately. Apologies for the inconvenience...
Thanks, Zenzen. The forum does note while you write a post that the URL has been posted before, but in the case of Battle.net, where it's literally the name of the thing being discussed as much as the URL, that ought not to happen--and account deletion (as opposed to being disabled) should never be an automated process. If that's a configurable setting and anyone is able to change it, I'd encourage that.
Not a big problem, just a shock! I saw the message saying the "url was already used" but didn't think it would jeopardize my account since my conversation was legitimate.
As for us and our problem, now that the conversation is restored, I was able to replicate the Bottles error in terminal and this is EVERYTHING that is triggered after clicking "Play" and getting the error message displayed :
0b44:err:kerberos:kerberos_LsaApInitializePackage no Kerberos support, expect problems
0b18:err:ole:com_get_class_object apartment not initialised
0b18:err:module:import_dll Library libvkd3d-1.dll (which is needed by L"C:\\windows\\system32\\wined3d.dll") not found
0b18:err:module:import_dll Library libvkd3d-shader-1.dll (which is needed by L"C:\\windows\\system32\\wined3d.dll") not found
0b18:err:module:import_dll Library wined3d.dll (which is needed by L"C:\\windows\\system32\\d3d12.dll") not found
0b18:err:module:import_dll Library d3d12.dll (which is needed by L"C:\\Program Files (x86)\\Diablo IV\\sl.common.dll") not found
warn:  DXGIDeclareAdapterRemovalSupport: Stub
warn:  CreateDXGIFactory2: Ignoring flags
info:  Game: Diablo IV.exe
info:  DXVK: v2.7.1
info:  Build: x86_64 gcc 15.1.0
info:  Found built-in config:
info:    dxvk.hideIntegratedGraphics = True
info:    dxgi.hideNvidiaGpu = False
info:  Effective configuration:
info:  Vulkan: Found vkGetInstanceProcAddr in winevulkan.dll @ 0x6ffffc64e430
info:  Extension providers:
info:    Platform WSI
info:    OpenVR
info:  OpenVR: could not open registry key, status 2
info:  OpenVR: Failed to locate module
info:    OpenXR
warn:  OpenXR: Unable to get required Vulkan instance extensions size
info:  Enabled instance extensions:
info:    VK_EXT_surface_maintenance1
info:    VK_KHR_get_surface_capabilities2
info:    VK_KHR_surface
info:    VK_KHR_win32_surface
info:  Found device: NVIDIA GeForce RTX 5070 Ti (NVIDIA 580.95.5)
warn:  OpenXR: Unable to get required Vulkan Device extensions size
That's actually a different error than I had gotten, which explains why you still get it.
I can run a 2D game like Dungeon Keeper Gold, but I can't run a 3D game like Thief Gold. (I raided my GoG library for small games with offline installers. :smiley: )
Thief does not have clear errors going on. I see these "info" lines, then a "warn" line, then these before a couple "dumps".
warn:  D3D9DeviceEx::SetRenderState: Unhandled render state 161
info:  DXVK: Using 16 compiler threads
wine: Unhandled page fault on read access to 00000018 at address 79CEF338 (thread 012c), starting debugger...
01d0:fixme:dbghelp:elf_search_auxv can't find symbol in module
Unhandled exception: page fault on read access to 0x00000018 in wow64 32-bit code (0x79cef338).
Anyway, let's not deep dive in Bottles' problems.
I can play. You are still my hero.
Thanks a lot! :slight_smile:
Just putting it out there that your instructions for Heroic worked flawlessly on the first try.
Cheers.
