Hi, I have installed Zorin 15.3 on my HP 7-ca1124ng laptop, but it will not boot on battery power. It starts the boot process then the screen goes blank. Can any one please help.
dbvoss
After you get it booted while plugged-in, does the battery alone sustain operation after that (unplugged)?
Could you please edit your grub by
sudo nano /etc/default/grub
Find this line:
Change it to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash dis_ucode_ldr"
Hit ctrl+x to exit, hit 'y' to say yes, then hit enter to save as current title.
Then
sudo update-grub
Hi carmar,
Yes once i have booted when plugged-in and then unplugged its OK.
dbvoss
Hi Aravisian,
I did as you suggested but it will still not boot on the battery power.
dbvoss
Ok, please see here:
and scroll down to the "UPDATE comments toward the bottom. Please let us know if any of these tips on that site help you to resolve.
Hi.Aravisian,
I enabled auto Login and now it boots
OK. Thanks for your help.
dbvoss
Hi carmar,
dbvoss
That is not the solution I would have expected. Glad you were able to get it figured out and shared your results.
