I am trying to use a shell theme but it do not work
I am trying to make my zorin looks like more a windows 7, but when I change the shell configuration on the appearance menu it just doesn't work.
Welcome to the forum!
So I assume by the Appearance menu you mean Zorin Appearance? Just wanting to clarify. What I would try doing is updating your computer and then rebooting, just to make sure that nothing there is screwing things up:
sudo apt update
sudo apt upgrade
Then once those commands are done, reboot your computer. Then try Zorin Appearance again and see if the issue resolves itself or not. This is generally the most default fix I try before anything else.
Is Your Theme listed in Zorin Appearance?
Where did You put the Theme? I mean in what Path.
Could You maybe post some Screenshots?
