I have another problem I want to launch a game
I have herioc launcher I want to launch marvel rivals thats happen to me and its want wine so I install the wine inside the launcher this is the photo okay if ths photos is not appears this is the problem
I will write it A debugger has found running in your system please unload it from memory and restart your program
This looks a lot like Game Developers Anti-Cheat methods.
The reason this stumbles on GnuLinux is because Wine creates a compatibility layer (Proton and Wine operate the same way) that debugs as it runs, which Game Developers use software that often misinterprets as tampering.
Additionally, anti-cheat uses hidden scanning to check for debugging operations.
You might have some luck using Bottles instead of Wine.
I can offer little help on setting that up, since I have never used Bottles, not attempted a Mainline Title that uses obfuscated anti-cheat methods that serve the game maintainers self interest while pushing the end users out the door.
Okay what the step how to install bottles that means the wine is anticheat right great I want the bottle how to install it thank you what you meant it right?
I think there will still be issues, because whatever method you use, WINE or bottles, it means the game is having to go through a mechanism before a connection is made when online gaming is involved. These delays are misinterpreted as though someone is using a software cheat, when all it is is a fraction of a second delay.
What that mean ?
You can install Bottles in the Software Center.
So install bottle is the solution install the bottles then sign in then play game in it right?
I seem to recall being made to play that game for a while with my friends when it first came out (to the tune of about 6 hours). From reports it seems it should still be working. Although I had it downloaded and playing through steam, I wasn't trying to run it through something else.
