I struggled with trying to get that .deb package to work and failed... So I turned to Larry Fingers provided drivers. It also needed a lot of footwork to get it installed as dkms which I did not really feel like trying to type out a book on here to walk through all the steps.
Instead, I packaged it as a .deb package that you can download and double click to install:
I tried it on the 2 kernel I have and it did something different:
on 6.2 it did this:
yves@yves-IdeaPad-Slim-3-15IRU8:~$ sudo modprobe -rv 8852be
[sudo] Mot de passe de yves :
yves@yves-IdeaPad-Slim-3-15IRU8:~$ sudo modprobe -v 8852be
insmod /lib/modules/6.2.0-060200-generic/kernel/drivers/net/wireless/8852be.ko
modprobe: ERROR: could not insert '8852be': Exec format error
And in 5.19 it did this:
modprobe: FATAL: Module 8852be not found.
I did't try the second command since the module wasn't found in the first one. When I tested it in 5.19, I uninstalled the .deb package before installing it again, it didn't change anything.
So i tried the live version from the USB stick and it seems to work perfectly, wifi was connected, could change the brightness and so I guess the sleep mode would work to, but I need to install it to test.
I was curious about Mint to, so I tried the version using 5.15 kernel and I couldn't connect on the wifi... I tried the edge version (working with kernel 6.2) and it seems to work.
I prefer to use Zorin, so unless there's any more ideas to make it work, I'll have to chose between connecting to the wifi from my phone or hurting my eyes looking at the screen before Zorin 17 is stable. They say a few weeks, could it be more then a month or within this month it could be released?
While Zorin OS 17 is in Beta testing; this does not mean it is very risky to use. If all your hardware works on it, if it was me, I would switch over to it.
Yes, there is. You can click your Profile Image on the upper right side of the page. Then click the "Person Icon" at the bottom of the right pane.
Click Preferences
Then click on Interface tab on the upper right of the tabs and look to the page Color Scheme
Hopefully this will be my last question...
I'll try to install zorin 17. My computer is already in dual boot windows and zorin 16.3. Can I install zorin 17 on the third partition and then uninstall zorin 16.3? I'd like to keep windows for now
