Hi all,
I am finally sorted all my issues with Zorin 16 core.
I can now install for real ( again) and maybe 16 pro.
What i am thinking is this ok ?
EFI partition 512 mb
root partition 220 gb ,ext4 or btrfs is better for snapshot backups ?
home partition 215 gb, ext4
swap partition or swap file ?
My laptop is :
CPU:
Topology: Quad Core
model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 33550
Speed: 1222 MHz min/max: 1400/2100 MHz boost: disabled
Core speeds (MHz): 1: 1222 2: 1222 3: 1231 4: 1275 5: 1266 6: 1223
7: 1259 8: 1248
Graphics:
Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 04:00.0 chip ID: 1002:15d8
Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 3-1:2 chip ID: 04ca:709d
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Audio:
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 04:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
bus ID: 04:00.5 chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.11-1-MANJARO
Network:
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A port: f000
bus ID: 02:00.0 chip ID: 10ec:b822
IF: wlo1 state: up mac: <filter>
Drives:
Local Storage: total: 942.70 GiB used: 6.97 GiB (0.7%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: HPS0
scheme: GPT
ID-2: /dev/sda type: USB vendor: HGST (Hitachi) model: HTS725050A7E630
size: 465.76 GiB rotation: 7200 rpm serial: <filter> scheme: GP
thanks
