Can you check your netspeed? I wonder if the repository failure is related to packet loss to your network.
Is Telegram installed as a Flatpak or APT package?
The Software Store uses a Plugin for managing Flatpak and Snap packages. This is because it normally handles APT packages.
In terminal, please try running
flatpak update
or
flatpak update org.telegram.desktop
Great. Now,
killall gnome-software
Then launch Software store from the app menu and check if everything seems to be working properly.
Yes working,seems all are working
