Installation error
Hello everyone,
I want to do a dual boot on my computer, with W10 and Zorin, and I have an issue during the installation(see on the images) do you guys can help me?
Thankfull any answer
Is the installation stuck that way? If yes, then for how long?
Yes, 1 hour, I made the switch and EFI, and I selected where I wanted to install
Sorry for the late reply. I had gone offline.
I am sorry, I don't know how to fix this. The reason I asked you, for how long the installation was stuck, is because I recieve this error too every time I install Ubuntu or any ubuntu based distro. But the error goes after a minute or two.
Meanwhile, you can try this:
https://itectec.com/ubuntu/ubuntu-xdg_runtime_dir-is-not-owned-by-us-uid-0/
or wait for others to help.
No problem, Thank you man, I never did dual boost before,I generally use the VMware.
