Installing guitar plugins
I just don't understand how I should install plugins in Zorin. I'm trying install these: Chowdhury DSP - Products
I click the .deb file and it opens in package installer (not sure if that's the correct name for it). I press install and it says "installed" but nothing else happens. I can't find vst3 files or any plugins and so I can't add them to Reaper. Same is with yabridge, everything just goes over my head. Some guides tell I should put vst or whatever to certain directory like ~./vst3 but I have no clue where those are.
Can some help how to setup chowdsp plugins and https://www.powerdrumkit.com/ to Reaper? Thank you.
I'm not familar with this software.
In which package format is reaper installed? When it is a flatpak, you should install flatseal and in flatseal change the permissions for reaper to grant access to to users/system files.
Or you could try to install reaper from the homepage
Yes it's flatpak. I installed flatseal but no difference. I just don't understand how to get those .deb files to work. I have Chowdsp BYOD standalone version and it works fine, I found it from Software store. Shame there is no VSTs also.
Okay just random youtube comment fixed the problem. I just needed to create myself .vst3 folder to home directory and then extract the .deb-files and move the vst3 plugins to the created .vst3 folder. Now Reaper finds them. Lol
Hey there - thanks for sharing your experiences, it helped me, too :grin:
Did you ever get MT Power Drumkit to work?
Because I can't; Yabridge tells me it's synced but Reaper fails to scan it...
