The instructions provided for our Brother printer (scan/fax/copy) machine for Linux are as follows -
1. Login as a superuser ( or use "sudo" option if it is required )
2. Download driver.
Download Linux driver.
3. Install Linux driver
1. Turn on the printer and connect the USB cable.
2. Open the terminal and go to the directory where the driver is.
3. Install Linux driver. The install process may take some time. Please wait until it is complete.
Command (for dpkg) : dpkg -i --force-all (linux-drivername)
4. Check if the Linux driver is installed
Command (for dpkg) : dpkg -l | grep Brother
I have downloaded the driver file - mfcj995dwpdrv-1.0.5-0.i386.deb [in Download folder] but am not sure about what to put into the terminal.
is the "sudo" option required? If so how should the terminal entry be?
do I type the entireCommand line (replacing linux-drivername with mfcj995dwpdrv-1.0.5-0.i386.deb)??
They are a bit enthusiastic, aren't they?
I would suggest double clicking the .deb file you downloaded and letting the installer run.
IF it has trouble, then you can resort to usinga force-all command on it...
The answer would be "yes" on both of these, in case it comes to that. You are at the head of the class.
There is an easier method. Install Gdebi (package manager) using Synaptic, just search for Gdebi, mark for installation, then select apply. Run Gdebi (you will be asked for your login password to elevate to 'root') then use Gdebi to point to the downloaded .deb file. Restart your computer for the changes to take effect (installation of Printer driver). Then open Printers, select Brother then scroll down to the model of your printer - the .deb file will have been added to the Printers selection.
I did double click the downloaded .deb file which added the Brother Inkjet Printer Driver mfcj995dwpdrv into Add-ons. I don't see any Printer in any of the Start 'bar' categories. Should I remove this Add-on before I try second/the Gdebi method?
I can not find a 'Printers section' - where is that usually located (in Start bar) - Accessories? Office? System Tools? Utilities?? OR do I need to add a Printer Category?
I did find Printers in Settings, but there are (now) TWO with near same (model) name - one 'driverless' the other 'CUPS'. Any thoughts about which is best used?
