I installed Steam to try some games on Linux, however I encountered afterwards a weird issue.
After boot, my ethernet connection began to disconnect from the internet after 30min-1hour. The wireless connection was not affected.
I managed to solve the issue by uninstalling Steam and reinstalling the network-manager by using the steps from here How to reinstall network manager without internet access? - Ask Ubuntu
1. First boot from a Ubuntu Live disk.
2. Once you go there open a terminal and run the below command,
sudo apt-get download network-manager*
This will download all the network-manager packages to the home directory. Now copy all the .deb packages to a folder in that pen drive or other partitions in your HDD and then reboot to your system.
3. Once you go there open terminal and do the following:
cd /path/to/the/directory/where/.deb/files/are/located
sudo dpkg -i *.deb
The above command will install all the .deb files.
4. Now restart your network-manager by running sudo service network-manager restart.
Now you have the package network-manager-gnome running again.
I don't really need Steam but wanted to share the solution for people that may encountered a similar issue.
